Toshiba A1304T Mini LCD Screen Replacement
Выберете то, что вам нужно
  1. Toshiba A1304T Mini LCD Screen Replacement, Front Cover: шаг 1, изображение 1 из 1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Toshiba A1304T Mini LCD Screen Replacement: шаг 2, изображение 1 из 2 Toshiba A1304T Mini LCD Screen Replacement: шаг 2, изображение 2 из 2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Mini LCD Screen Replacement: шаг 3, изображение 1 из 2 Toshiba A1304T Mini LCD Screen Replacement: шаг 3, изображение 2 из 2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
  4. Toshiba A1304T Mini LCD Screen Replacement, Mini LCD Screen: шаг 4, изображение 1 из 2 Toshiba A1304T Mini LCD Screen Replacement, Mini LCD Screen: шаг 4, изображение 2 из 2
    • Using a small Phillips screwdriver, gently pry off the LCD screen from the board.
  5. Toshiba A1304T Mini LCD Screen Replacement: шаг 5, изображение 1 из 2 Toshiba A1304T Mini LCD Screen Replacement: шаг 5, изображение 2 из 2
    • Using the head of the screwdriver, flip up the black tab connecting the ribbon-wire.
    • Gently pull the LCD screen away from the board, the cable should come off with nearly no resistance.
Заключение
Еще один человек закончил это руководство.
Christopher
Участник с: 04/22/10
90 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 16-6, Maness Spring 2010 Участник Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 членов
Автор 16 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,902
