Введение
The only hard thing about the guide is making sure the wire does not get in the way!
Выберете то, что вам нужно
Remove the 2 rubber foot pads from the bottom (opposite the hinge) with the small Plastic Opening tool.
Loosen the back cover by using a plastic opening tool all the way around the device.
Remove the tape holding the speaker wire to the battery on both sides using a small opening tool.
Remove the 4 Phillips 3.2 mm screws holding the battery in place, with the Phillips #1 screwdriver.
To disconnect the wire from the mother board, gently press down with the flat end of Spudger and pull on the wire.
Remove the 4 Phillip 6.3 mm screws from both the right and left speakers using Phllips 1 screwdriver.
Gently remove wire from the motherboard by pulling it out of the connector socket.
