Toshiba Canvio Connect V73600-C Disassembly
Выберете то, что вам нужно
  1. Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: шаг 1, изображение 1 из 2 Toshiba Canvio Connect V73600-C Disassembly, Begin opening case: шаг 1, изображение 2 из 2
    • On the side of your hard drive casing, insert a spudger.
    • This can be tricky as the tolerances are quite tight.
    • I used a needle to make the gap big enough to insert a pick.
  2. Toshiba Canvio Connect V73600-C Disassembly, Continue opening: шаг 2, изображение 1 из 1
    • Slide your spudger along the gap in the casing you made in the previous step, continuing to open the device.
  3. Toshiba Canvio Connect V73600-C Disassembly, Keep going: шаг 3, изображение 1 из 1
    • Slide the spudger around the corner of the casing to start opening the next side.
    • There may be a gap big enough to see the plastic clips holding the device together.
  4. Toshiba Canvio Connect V73600-C Disassembly, Prise the casing open: шаг 4, изображение 1 из 1
    • Once there is a big enough gap in the casing, gently prise the two parts away from each other, being sure not to break any clips.
    • This will reveal the hard drive in the casing.
  5. Toshiba Canvio Connect V73600-C Disassembly, Extract the hard drive: шаг 5, изображение 1 из 1
    • Simply lift the drive out of the case.
    • There may be some friction due to the anti-shock rubber on the corners of the drive.
    • Gently pry with a plastic pry tool if required.
  6. Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: шаг 6, изображение 1 из 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: шаг 6, изображение 2 из 3 Toshiba Canvio Connect V73600-C Disassembly, Realise the drive is not suitable for internal use: шаг 6, изображение 3 из 3
    • As the drive has a USB port soldered directly to its logic board, instead of a converter board in between, disassembling this device seems to be pointless unless the hard drive is being used for parts.
Заключение
2 участников успешно повторили данное руководство.
CONVERSION
Участник с: 03/07/20
1 252 Репутация
Автор 8 руководств
Команда
Australia Участник Australia
Community
4 членов
Автор 11 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 32
За последние 30 дней: 160
За всё время: 4,766
