Введение
This guide willl help guide you through the process of replacing a faulty or dead battery in a Toshiba Dynabook T552-58G. There are no tools required for this guide.
Push the right battery cover lock (labeled as number 1) to the right.
It should now be on the unlock symbol.
Push and hold the left battery cover lock (labeled as number 2) to the left.
It should now be on the number 2.
While holding the left battery cover lock, pull up on the indent found in the center of the battery pack.
Lift up on the battery pack to remove it from computer.
Еще один человек закончил это руководство.
