Введение
This guide will walk you through the process of replacing a fan in the Toshiba Dynabook T552-58G. You will need to replace the fan if it is faulty or broken. There are a few tools required for this guide.
Выберете то, что вам нужно
Turn the Toshiba Dynabook T552-58G so that the back panel is facing you.
Remove the 10 screws located on the back panel of the Toshiba Dynabook T552-58G using a PH 0 screwdriver.
Remove the black screw using the J0 screwdriver. This is located by the top right foot of the device.
This will allow removal of the hard drive cover.
Remove the single screw located below the hard drive using the J0 screwdriver. This screw is 5.3 mm long.
Remove two screws located diagonally from the bottom-left screw of the hard drive using a J0 screwdriver. The screw closest to the hard drive is 5.2 mm long and the screw farther away is 4.2 mm long.
Remove the screw located diagonally from the top right screw of the hard drive using a J0 screwdriver. This screw is 5.2 mm long.
Slowly lift the back panel away from the computer.
Once lifted, carefully remove the back panel.
Remove the two screws located on the top left and bottom right of the fan. You should use a PH 0 screwdriver.
Gently lift the fan away from the base. There should be three wires that are connected to the base of the computer through a port.
