Введение
The following guide shows detailed steps to remove the onboard speaker from a Toshiba Encore Mini. Be sure to back up data to an external device before attempting any component replacement.
Выберете то, что вам нужно
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
Carefully use the metal spudger to remove the speaker from the frame of the phone.
Почти готово!
Заключение
