Toshiba Encore WT8-A Tablet Motherboard Replacement
Выберете то, что вам нужно
  1. Toshiba Encore WT8-A Tablet Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Use the metal spudger to create a gap between the back cover and the device.
    • Be gentle when using the metal spudger so that the casing is not damaged.
  2. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 2, изображение 1 из 2 Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 2, изображение 2 из 2
    • Use the nylon spudger to completely separate the back of the device.
    • Take the nylon spudger around the outside of the device cover until it comes free.
  3. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 3, изображение 1 из 2 Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 3, изображение 2 из 2
    • Use the Phillips head PH0 to remove the 7 battery screws.
    • The 5 side screws measure 3.5mm.
    • The 2 top and bottom screws measure 4.5 mm.
  4. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 4, изображение 1 из 2 Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 4, изображение 2 из 2
    • To disconnect the cable, use the fine tweezers to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • The zero insertion force (ZIF) connector is used to secure delicate ribbon cables, such as this trackpad cable.
  5. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 5, изображение 1 из 1
    • Remove the colored power cable from its connector.
    • To disconnect it safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Be sure to be very gentle when prying colored wires from motherboard to ensure that there is no damage.
  6. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 6, изображение 1 из 1
    • Battery will lift out of the device.
  7. Toshiba Encore WT8-A Tablet Motherboard Replacement, Motherboard: шаг 7, изображение 1 из 1
    • Remove the 4 – 4.5 mm screws from the motherboard assembly.
  8. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 8, изображение 1 из 1
    • Remove the 2 – 3.5 mm screws from the motherboard assembly.
  9. Toshiba Encore WT8-A Tablet Motherboard Replacement: шаг 9, изображение 1 из 1
    • The motherboard should come free at this point.
Заключение
Еще один человек закончил это руководство.
Zachary Armstrong
Участник с: 09/15/16
293 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 17-4, Blackwell Fall 2016 Участник USF Tampa, Team 17-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G4
3 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 1,949
