Toshiba Excite 7 Battery Removal
Выберете то, что вам нужно
  1. Toshiba Excite 7 Battery Removal, Battery Removal: шаг 1, изображение 1 из 3 Toshiba Excite 7 Battery Removal, Battery Removal: шаг 1, изображение 2 из 3 Toshiba Excite 7 Battery Removal, Battery Removal: шаг 1, изображение 3 из 3
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Battery Removal, Remove Tape: шаг 2, изображение 1 из 2 Toshiba Excite 7 Battery Removal, Remove Tape: шаг 2, изображение 2 из 2
    • Remove any black tape from the device.
    • Keep the tape, you will need to put it back on when you are done.
  3. Toshiba Excite 7 Battery Removal, Unplug Wires: шаг 3, изображение 1 из 2 Toshiba Excite 7 Battery Removal, Unplug Wires: шаг 3, изображение 2 из 2
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it, one just above the battery and one just to the right.
  4. Toshiba Excite 7 Battery Removal, remove screws: шаг 4, изображение 1 из 2 Toshiba Excite 7 Battery Removal, remove screws: шаг 4, изображение 2 из 2
    • Unscrew the battery from the device.
    • The device has 5 screws to remove, keep the screws.
  5. Toshiba Excite 7 Battery Removal, Unclip and remove battery: шаг 5, изображение 1 из 2 Toshiba Excite 7 Battery Removal, Unclip and remove battery: шаг 5, изображение 2 из 2
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery, they may fall off.
    • Push the clip back then lift the battery up.
Заключение
4 участников успешно повторили данное руководство.
osmel fermin
Участник с: 01/15/15
176 Репутация
1 руководство автора
Команда
USF Tampa, Team 1-3, Tanski Winter 2015 Участник USF Tampa, Team 1-3, Tanski Winter 2015
USFT-TANSKI-W15S1G3
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,748
