Toshiba Excite 7 Screen Replacement
Выберете то, что вам нужно
  1. Toshiba Excite 7 Screen Replacement, Battery Removal: шаг 1, изображение 1 из 3 Toshiba Excite 7 Screen Replacement, Battery Removal: шаг 1, изображение 2 из 3 Toshiba Excite 7 Screen Replacement, Battery Removal: шаг 1, изображение 3 из 3
    • Remove the back cover.
    • Work your fingernail or flat object under the cover’s seal. Start at the top right corner just above the front facing camera this is the device “Weak Spot”.
    • After you pry open the first clip slide the flat object along the perimeter of the cover until the cover is removable. You should hear the clips pop open.
  2. Toshiba Excite 7 Screen Replacement, Remove Tape: шаг 2, изображение 1 из 2 Toshiba Excite 7 Screen Replacement, Remove Tape: шаг 2, изображение 2 из 2
    • Remove any black tape from the device.
    • Keep the tape, you will need to put it back on when you are done.
  3. Toshiba Excite 7 Screen Replacement, Unplug Wires: шаг 3, изображение 1 из 2 Toshiba Excite 7 Screen Replacement, Unplug Wires: шаг 3, изображение 2 из 2
    • Unplug the wires from the battery.
    • The battery is the black rectangle in the middle of the device. The device has two wiring harnesses attached to it, one just above the battery and one just to the right.
  4. Toshiba Excite 7 Screen Replacement, remove screws: шаг 4, изображение 1 из 2 Toshiba Excite 7 Screen Replacement, remove screws: шаг 4, изображение 2 из 2
    • Unscrew the battery from the device.
    • The device has 5 screws to remove, keep the screws.
  5. Toshiba Excite 7 Screen Replacement, Unclip and remove battery: шаг 5, изображение 1 из 2 Toshiba Excite 7 Screen Replacement, Unclip and remove battery: шаг 5, изображение 2 из 2
    • The battery has one clip you will need to remove. The clip is located at the bottom right corner of the battery just above the right speaker. The speakers and wires are not secured to the battery, they may fall off.
    • Push the clip back then lift the battery up.
  6. Toshiba Excite 7 Screen Replacement, Remove Data cable: шаг 6, изображение 1 из 1
    • The screen is connected to the circuit board by 2 “Data Cables” (orange ribbons). Data cables include 3 working components, data cables, the white harness plug, and the black lever.
    • Gently flip the black lever up and unplug data cables.
  7. Toshiba Excite 7 Screen Replacement, Removing the Circuit Board: шаг 7, изображение 1 из 1
    • Remove the circuit board by gently coaxing it from the clips located just to the right of the circuit board.
  8. Toshiba Excite 7 Screen Replacement, Installing the Replacement Screen Assembly: шаг 8, изображение 1 из 2 Toshiba Excite 7 Screen Replacement, Installing the Replacement Screen Assembly: шаг 8, изображение 2 из 2
    • The screen has a rubber device used to support the volume control switch.
    • Remove the rubber device from the old screen.
    • Make sure you keep the rubber device to be install into the new screen.
    • Repeat other steps in reverse to install replacement screen.
Заключение
Sean Ulch
Участник с: 01/15/15
340 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 1-3, Tanski Winter 2015 Участник USF Tampa, Team 1-3, Tanski Winter 2015
USFT-TANSKI-W15S1G3
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,262
