Введение
Use this guide to replace the top panel of your device.
Выберете то, что вам нужно
Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
Using your hand, gently lift the black top panel and safely place it off to the side.
Почти готово!
Заключение
