Введение
We will show you how to find and remove the wifi card. This is a simple procedure and only requires a few steps.
Выберете то, что вам нужно
Use your left hand to hold latch 2 to the left.
Simultaneously take the battery out with your right hand.
Locate the two torx T-6 screws on the back of the laptop and remove them.
6mm Torx T-6 Screws
Remove the two Phillips 0 size screws on WIFI card.
Once the screws are removed the WIFI card will raise up
Grip both sides of the wifi card with your hand.
Lift up on the card and pull the card out of the slot
