Введение
Keybaord replacement for this laptop is simple and only requires a screwdriver and a plastic opening tool.
Выберете то, что вам нужно
Begin by removing the battery and flipping the laptop over to see the screws
Using a phillips head screwdriver to remove the screws that secure the back
Flip the laptop back over and open it up carefully
Lift up the bottom panel where the mouse click buttons are
Using the spudger disconnect the ribbon cable connected to the bottom of the panel
Using the same size phillips as before remove the two screws that hold the keyboard in place
Lift the keyboard up and slide it downwards and out.
