Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will go through the steps needed to install a new hard drive.
Выберете то, что вам нужно
Slide the lock on the left side to the unlock position.
Slide the lock on the right side to the unlock position until there is a clicking sound.
Turn the computer over onto the back.
Use a Phillips head screwdriver to remove the screw from the hard drive cover.
One 8.5 mm fine thread screw.
Lift and remove the cover.
Carefully remove the hard drive from the IDE cable by pulling on the black connector (do not pull the orange cable).
5 участников успешно повторили данное руководство.
