Введение
This guide will go through the steps needed to install a new LCD panel. It's a fairly quick procedure, but it does require some care as it involves very delicate components and short wires that aren't immediately visible. This should be a fairly easy repair if you take it slowly and don't move anything around too roughly—displays are delicate components! Good luck!
Выберете то, что вам нужно
Slide the lock on the left side to the unlock position.
Slide the lock on the right side to the unlock position until there is a clicking sound.
Remove the rest of the cover by sliding it to the right and lifting the right edge.
Remove all eight plastic circular covers on the plastic screen bezel.
Unscrew all seven screws with a Phillips head #000 screwdriver.
Use a plastic opening tool to separate the screen bezel from the rest of the case.
Pull at the top edge of the LCD to separate it from the top part of the case.
Use a Phillips #000 to unscrew the one 2.8 mm fine thread screw holding the wire connected to the right face of the LCD.
Flip the LCD over onto the back.
Gently pull the connection on the corner of the LCD to disconnect.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the tape connecting LCD to the inverter.
Use tweezers to remove the LCD cable from the inverter.
Еще один человек закончил это руководство.
