Введение
In this guide, you will learn how to replace a battery that doesn't charge properly or anymore. This guide will also teach you what the proper and necessary tools are for this repair.
  1. Make sure the battery lock switch is switched to the unlocked position. Slide the battery release switch to the up.
    • Make sure the battery lock switch is switched to the unlocked position.
    • Slide the battery release switch to the up.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Using your hand, lift up the battery. The battery release switch must be held in place.
    • Using your hand, lift up the battery.
    • The battery release switch must be held in place.
Заключение
Varsha Roopreddy
Участник с: 19.04.2013
1 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 4-17, Maness Spring 2013 Member of Cal Poly, Team 4-17, Maness Spring 2013
CPSU-MANESS-S13S4G17
3 членов
Автор 4 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 714
