Выберете то, что вам нужно
Use a Phillips screwdriver to remove the two screws securing the hard driver cover.
Gently lift the plastic cover from the back case and slide it out from its position.
Gently lift the plastic tab and carefully remove the hard drive from its socket.
You are done!
Почти готово!
Заключение
