Введение
In this guide, you will learn how to disassemble the broken/damaged screen from the rest of the laptop, allowing you to replace it for a new one. This guide will also teach you what the proper and necessary tools are for this repair.
Выберете то, что вам нужно
With a plastic opening tool, prop the plastic panel up to separate it from the rest of the laptop.
Slowly pull the plastic panel from the entire laptop.
Remove the four 5 mm screws with a Phillips #1 screwdriver, each located at the four corners of the screen.
At this point, the screen should be completely disconnected from the rest of the laptop.
Еще один человек закончил это руководство.
Один комментарий
Be careful with this procedure, as there are at least 2 different part numbers for the M400, LTD121KM7K has a 32 pin connector, and a different one, LTD121KC6K has a shorter connector for the display which is not compatible. When ordering from Ebay they do not distinguish between them. I would also like a procedure for replacing the complete screen and lid assembly. I can't find it on the net at the moment. Also, be aware that there may be compatibility issues there too.
