Введение
For this guide we will be opening up the laptop to replace the CD drive.
Выберете то, что вам нужно
Slide both latches to the unlocked position to release the battery.
Pull the battery toward you while holding the left latch.
Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
Flip the CD Drive over carefully, lifting the right side and turning the drive in order to reveal the attachment.
Remove the two 4 mm screws with the Phillips 00 screwdriver.
Pull the ribbon cable away from the laptop to release the CD drive from the computer.
Еще один человек закончил это руководство.
