Toshiba Portege R500 Cooling Fan Replacement
Выберете то, что вам нужно
  1. Toshiba Portege R500 Cooling Fan Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Portege R500 Cooling Fan Replacement, Battery: шаг 1, изображение 2 из 2
    • Make sure the device is off to prevent data loss.
    • Slide both latches to the unlocked position to release the battery.
    • Switch the latch on the right to reveal red. The latch on the left needs to be held.
    • Pull the battery toward you while holding the left latch.
  2. Toshiba Portege R500 Cooling Fan Replacement, Cooling Fan: шаг 2, изображение 1 из 1
    • Remove the sixteen screws at the locations shown with the Phillips 00 screwdriver.
  3. Toshiba Portege R500 Cooling Fan Replacement: шаг 3, изображение 1 из 1
    • Pull up on the back casing and remove it.
  4. Toshiba Portege R500 Cooling Fan Replacement: шаг 4, изображение 1 из 1
    • Remove the two 5.5 mm screws from the fan with the Phillips 00 screwdriver.
  5. Toshiba Portege R500 Cooling Fan Replacement: шаг 5, изображение 1 из 1
    • Disconnect the fan's power connector using the rounded handle plastic opening tool.
    • The fan should now be free of the laptop and can be removed.
Заключение
JRJones
Участник с: 04/19/13
169 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 2-19, Maness Spring 2013 Участник Cal Poly, Team 2-19, Maness Spring 2013
CPSU-MANESS-S13S2G19
3 членов
Автор 15 руководств
2 Комментариев
Don't forget the silver compound when re-assembling
Graham Smith - Ответить
If you really can’t find a replacement fan (which most people can’t) just gently clean the top of the CPU and back of the cooler fan with a cotton swab and and an alcohol wipe and gently re-apply some new thermal paste to both the top of the CPU and back of the cooler. What happens is the thermal paste dries out after a few years due to the CPU’s excessive heat thus causing the CPU to gointo thermal shutdown. My R600 works fine now and the entire job only takes 30 ~45 minutes and anyone who can use a use a small phillips screwdriver should be able to do this job without much difficulty. Just be sure to have 3 or 4 small containers to hold the different size screws and be careful as the screws are very very small and can get lost extremely easily if one is not careful. Also, clip the buds off a cotton swab and use this little stick to help you remove the CPU attachment end of the fan where it attaches to the motherboard.
wilson_mah - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 15
За всё время: 3,734
