Введение
Is your computer overheating? Your cooling fan may need to be replaced. This guide will show you the steps for replacing the cooling fan in your Toshiba Portege R835-P88.
Выберете то, что вам нужно
Remove the three small covers from the bottom by removing two 11mm screws and three 5mm screws using a screwdriver #J000.
Remove the remaining screws from the bottom cover using phillips head screwdriver #PH00.
Pry the bottom cover using blue plastic ifixit prying tool.
Lift up and remove cover.
Disconnect the fan cable from the motherboard.
Remove two 3mm screws from fan using #J000 phillips head screwdriver.
Lift up and remove fan.
Replace the fan.
Assemble the Toshiba Portege R835-P88 following all disassembly steps in the reverse direction.
Еще один человек закончил это руководство.
