Toshiba Portege Z835-P330 Battery Replacement
Выберете то, что вам нужно
  1. Toshiba Portege Z835-P330 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Remove the thirteen 1.4mm screws on back of device using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Battery Replacement: шаг 2, изображение 1 из 1
    • Locate hidden screw found in the middle of back hardcover.
    • Found under rubber covering shown in picture.
    • Remove the single Torx Security screw using a TR7 screwdriver.
  3. Toshiba Portege Z835-P330 Battery Replacement: шаг 3, изображение 1 из 1
    • Peel off hardcover to expose interior of device.
    • Force may be required but hardcover should detach smoothly.
  4. Toshiba Portege Z835-P330 Battery Replacement: шаг 4, изображение 1 из 1
    • Remove the six 1 mm screws using a Phillips #1 screwdriver.
  5. Toshiba Portege Z835-P330 Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the white plug connected to the battery by gently pulling it out of the socket.
    • Plug should easily detach without force.
  6. Toshiba Portege Z835-P330 Battery Replacement: шаг 6, изображение 1 из 1
    • Lift battery up by its sides, and it should easily come off.
Заключение
2 участников успешно повторили данное руководство.
Dominic Whiting
Участник с: 02/08/18
915 Репутация
Автор 5 руководств
Команда
University of North Texas, Team S2-G3, Thomas Spring 2018 Участник University of North Texas, Team S2-G3, Thomas Spring 2018
UNT-THOMAS-S18S2G3
4 членов
Автор 15 руководств
6 Комментариев
These steps also work for the Z935-P300. NOTE: the center screw in step two is a Torx Security TR7.
Jim Flattery - Ответить
Will it lose it’s memory when the power and battery are disconnected? Do I need to back it up before I do this? My battery is so dead that the laptop shuts down after just a few minutes without the ac cord plugged in.
Thank you!
pat_brady_pb@yahoo.com - Ответить
I suspect you have already completed your repair and now know the answer, however, in the event that you are still waiting on a response. The short answer is no, the storage drive will not loose data when changing the battery. Despite this, it is always wise to have a backup.
Jim Flattery -
Could anyone please tell me which type of screws are these ?
lourencopintodasilva - Ответить
Which screws are you referring to? I believe they all have their details size and type listed above. Is there one in particular you need further detail on?
Jim Flattery -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 30
За всё время: 4,299
