Выберете то, что вам нужно
Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
Locate hidden screw found in the middle of back hardcover.
Remove the single Torx Security screw using a TR7 screwdriver.
Find the solid-state drive located below the battery, and next to the RAM.
Unscrew the two 1mm screws located at the top of the solid-state drive with a Phillips #1 screwdriver.
Еще один человек закончил это руководство.
