Введение
If your computer is running slow or becomes cold this can be due to a faulty RAM or you not having enough RAM in the computer. Use this guide to remove and replace your RAM.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to unscrew the single 8 mm screw and remove the RAM cover.
Using the iFixit opening tools, press on the two metal pieces holding the RAM cartridge in place. Do this for both RAM cards.
Еще один человек закончил это руководство.
