Введение
If you need to get to the Hard Disk Drive or need to remove the CD drive, use this guide.
Выберете то, что вам нужно
Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
Pull off the part of the case that's now loose by the indicated tab.
Почти готово!
Заключение
