Введение
This guide gives instructions on how to remove the disc drive of the Toshiba SD-K740 DVD player.
Инструменты
Запчасти
Детали не указаны.
Remove the three .303 inch screws from the back panel using a Phillips #0 screwdriver.
Lift and push away each of the two tabs located in the middle of the player.
Remove the first of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the second of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the third of three ribbon cables on left hand side of disc drive by pulling vertically.
Remove the four screws holding the disc drive in place using a #0 Phillips screwdriver.
Еще один человек закончил это руководство.
