Введение
This guide gives instructions on how to remove the disc drive front flap of the Toshiba SD-K740 DVD player.
Инструменты
Запчасти
Детали не указаны.
Remove the three .303 inch screws from the back panel using a Phillips #0 screwdriver.
Lift and push away each of the two tabs located in the middle of the player.
On back side of front panel very carefully apply pressure to the left hand side of the flap hinge.
Once the peg is free from the left restraint, carefully remove the left part of the flap.
Carefully remove the right peg from the restraint.
Remove the spring from the end of the right peg by pulling the door away from the spring.
