Введение
This guide gives instructions on how to remove the Right-Side Motherboard (Yellow) of the Toshiba SD-K740 DVD player, which controls the buttons and power function.
Инструменты
Запчасти
Детали не указаны.
Remove the three .303 inch screws from the back panel using a Phillips #0 screwdriver.
Lift and push away each of the two tabs located in the middle of the player.
Remove the black tie holding the two rear ribbon cables together by untwisting it.
Remove the first of two ribbon cables connected to the motherboard by pulling vertically.
Remove the second of two ribbon cables connected to the motherboard by pulling vertically.
Remove the three .303 inch screws attaching the inverter board to the casing using a #0 Phillips screwdriver.
Push the inverter board forward and to the left to remove from the holding ledges.
Lift the inverter board from the back end and pull toward you to complete removal.
