Введение
This guide gives instructions on how to remove the fuse located on the yellow motherboard of the Toshiba SD-K740 DVD player.
Инструменты
Запчасти
Детали не указаны.
Remove the three .303 inch screws from the back panel using a Phillips #0 screwdriver.
Use the plastic opening tool to gently pop the fuse out of the restraining brackets.
Еще один человек закончил это руководство.
