Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide gives instructions on how to remove the fuse located on the yellow motherboard of the Toshiba SD-K740 DVD player.
Выберете то, что вам нужно
Remove the three 7.7 mm screws from the back panel using a Phillips #0 screwdriver.
Turn the DVD player on its side.
Remove the 7.7 mm screw.
Flip the DVD player onto its other side.
Flip the DVD player over onto its front face.
Remove the back panel by lifting up and pulling it towards yourself.
Use the plastic opening tool to gently pop the fuse out of the restraining brackets.
Еще один человек закончил это руководство.
