Введение
Replacing or upgrading the hard drive is a simple procedure that results in improved storage and functionality.
Выберете то, что вам нужно
Unscrew the single small screw labeled F4 located on the right side of the panel.
Insert a spudger into the indent near the screw to pry open and remove the cover.
Use a spudger to disconnect the hard drive by shifting the entire drive to the right.
Почти готово!
Заключение
