Toshiba Satellite A105-S4011 Hard Disk Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the laptop over and locate the lock and battery release switches. Unlock the battery by changing the switch on the right from locked to unlocked by sliding the switch outward.
  2. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: шаг 2, изображение 2 из 2
    • Hold the release switch and pull out the battery towards you.
  3. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement, Hard Disk Drive: шаг 3, изображение 1 из 1
    • Turn the laptop so the battery-side of the laptop is farthest from you. Locate the captive screw pictured here and loosen the screw using the #1 Phillips screwdriver.
    • You may want to ground yourself before attempting to touch any components. This means touching a conductive metal to eliminate any static buildup in your body, which can damage computer components.
    • Make sure your new hard disk is compatible with your device before attempting to install it because it may not fit, may have different wiring, etc.
  4. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: шаг 4, изображение 1 из 1
    • Once the screw is completely removed, pull back the plastic cover carefully.
    • If you are having trouble removing the cover, a plastic removal tool may be used.
  5. Toshiba Satellite A105-S4011 Hard Disk Drive Replacement: шаг 5, изображение 1 из 1
    • Remove the hard disk by gently applying pressure with your thumb while sliding the hard disk to the left.
    • If you do not ground yourself, you run the risk of damaging your hard disk.
Заключение
4 участников успешно повторили данное руководство.
Connor Russell
Участник с: 04/18/13
49 Репутация
1 руководство автора
Команда
Cal Poly, Team 4-14, Maness Spring 2013 Участник Cal Poly, Team 4-14, Maness Spring 2013
CPSU-MANESS-S13S4G14
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 1,732
