Введение
After diagnosing your Toshiba Satellite A105-S4074, should you conclude that the battery is faulty and will need to be replaced, these simple and easy to follow instructions will guide you through the process.
Выберете то, что вам нужно
Slide both the left and right battery release tabs outwards away from center of the laptop.
While still holding the left release tab, slide the battery towards you using your right hand.
Fully remove the battery from the laptop.
To reassemble your device after inserting the replacement battery, follow these instructions in reverse order.
3 человек успешно провели ремонт по этому руководству.
