Toshiba Satellite A105-S4074 Hard Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A105-S4074 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite A105-S4074 Hard Drive Replacement, Battery: шаг 1, изображение 2 из 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Hard Drive Replacement: шаг 2, изображение 1 из 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: шаг 2, изображение 2 из 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: шаг 2, изображение 3 из 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Hard Drive Replacement, Hard Drive: шаг 3, изображение 1 из 3 Toshiba Satellite A105-S4074 Hard Drive Replacement, Hard Drive: шаг 3, изображение 2 из 3 Toshiba Satellite A105-S4074 Hard Drive Replacement, Hard Drive: шаг 3, изображение 3 из 3
    • Turn the laptop around so that the battery slot is facing away from you, and locate the hard drive access panel in the lower left-hand corner.
    • Locate the hard drive access panel in the lower left-hand corner on the bottom of the laptop, and loosen the 4.0 mm screw in the top center of the panel using the Phillips #1 screwdriver.
    • This is a captive screw and will remain intact with the panel.
    • Carefully remove the panel with your fingers by lifting the edge at the indent.
  4. Toshiba Satellite A105-S4074 Hard Drive Replacement: шаг 4, изображение 1 из 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: шаг 4, изображение 2 из 3 Toshiba Satellite A105-S4074 Hard Drive Replacement: шаг 4, изображение 3 из 3
    • You should now have full access to the hard drive.
    • Slide the hard drive to the left.
    • Gently lift the hard drive from the side closest to you and remove it.
Заключение
To reassemble your device after replacing the hard drive, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Ryan Bortnick
Участник с: 03/20/17
722 Репутация
Автор 5 руководств
Команду
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 Участник UMass Dartmouth, Team S2-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G1
4 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 1,396
