Toshiba Satellite A105-S4074 Keyboard Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A105-S4074 Keyboard Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite A105-S4074 Keyboard Replacement, Battery: шаг 1, изображение 2 из 2
    • To prevent electrical shock, make sure the computer is turned off; and disconnect the power adapter from the computer and electrical outlet prior to beginning any repairs on this device.
    • Turn the laptop upside down with the battery facing you.
  2. Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 2, изображение 1 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 2, изображение 2 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 2, изображение 3 из 3
    • Slide both the left and right battery release tabs outwards away from center of the laptop.
    • Right release tab will remain locked in place.
    • While still holding the left release tab, slide the battery towards you using your right hand.
    • Fully remove the battery from the laptop.
  3. Toshiba Satellite A105-S4074 Keyboard Replacement, Keyboard: шаг 3, изображение 1 из 2 Toshiba Satellite A105-S4074 Keyboard Replacement, Keyboard: шаг 3, изображение 2 из 2
    • Turn the laptop back over so it is right-side up, with the cover facing up.
    • Open the laptop all the way so that the screen is horizontal with the body.
  4. Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 4, изображение 1 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 4, изображение 2 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 4, изображение 3 из 3
    • Using the iFixit plastic opening tool, pop up the left tab along the top of the panel that is connected to the hinge for the widescreen display.
    • Using the plastic opening tool, pop up the right tab along the top of the panel that is connected to the hinge for the widescreen display.
    • Pry up and remove the cover panel that is located above the keyboard.
  5. Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 5, изображение 1 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 5, изображение 2 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 5, изображение 3 из 3
    • Position laptop so that both screws connecting the keyboard to the laptop are visible.
    • Unscrew the left 3.0 mm screw that is holding the keyboard onto the laptop using the Phillips #0 screwdriver.
    • Unscrew the right 3.0 mm screw that is holding the keyboard onto the laptop using the Phillips #0 screwdriver.
  6. Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 6, изображение 1 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 6, изображение 2 из 3 Toshiba Satellite A105-S4074 Keyboard Replacement: шаг 6, изображение 3 из 3
    • Gently lift the keyboard from either side where the screws were located.
    • Locate where the ribbon cable connects to the motherboard, and gently open clamp.
    • Pull out the ribbon cable connecting the keyboard to the laptop.
    • Avoid pulling directly on the ribbon cable while removing it, as this will cause permanent damage.
Заключение
To reassemble your device after replacing the keyboard, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Ryan Bortnick
Участник с: 03/20/17
722 Репутация
Автор 5 руководств
Команду
UMass Dartmouth, Team S2-G1, Isaacson Spring 2017 Участник UMass Dartmouth, Team S2-G1, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G1
4 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 6
За последние 30 дней: 10
За всё время: 526
