Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your keys are not typing anything or the way they should, then check this guide to see how to safely remove and replace the keyboard input device on the computer. It will also contain detailed pictures on what to expect and watch out for, such as ribbons or wires.
Выберете то, что вам нужно
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Using the Phillips screwdriver remove the two 4.0mm screws holding each of the speakers housings to the case.
Remove the speakers from the case being careful of the wires.
The wires for the speakers are color coded.The red and black wires are for the right speaker, and the black and white wires are for the left speaker.
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
Use the plastic opening tool to pop off tabs along the length of this panel.
Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
Lift the keyboard gently from the side closest the screen.
Pull out the ribbon connecting the keyboard to the laptop.
Еще один человек закончил это руководство.
