Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The motherboard is a essential part that contains the CPU and runs your computer and its systems, if its damaged then most likely it'll have to be replaced. This guide will show you how to get to the motherboard and replace it.
Выберете то, что вам нужно
Turn your laptop upside down, and slide the right release tab outward.
Using you left hand, hold the left release tab towards the left side and then pull the battery out.
Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
Use the plastic opening tool to pop off tabs along the length of this panel.
Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
Lift the keyboard gently from the side closest the screen.
Pull out the ribbon connecting the keyboard to the laptop.
Disconnect wire attaching LCD to motherboard
Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers
Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
Remove the seventeen 4.5mm phillips screws on the bottom of the laptop.
Using the pry tool separate the two halves of the laptop base.
Lift the top half of the case enough to get your hand beneath it, and then remove the two ribbon cables that connect it to the motherboard.
Remove the upper half of laptop and place bottom half in the center of your workspace.
Remove the one 2.00mm phillips screw.
Remove the ribbon cable connecting the USB ports to the motherboard.
Remove the two 2.5mm phillips screws holding the spring retainer for the heat sink.
Remove the two 4.0mm phillips screws holding the fan in place.
Remove the fan power connector.
3 участников успешно повторили данное руководство.
