Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will help you replace Toshiba Satellite A105-S4284 RAM. RAM allows memory to be accessed directly in a random order. You might need to replace a RAM if your computer shuts down abruptly, your computer performance is low quality, or the computer fails to install new programs.
  1. Make sure your computer is turned off and the computer is not plugged in. Turn your laptop upside down, and slide the right release tab outward.
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  2. Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver. You will not be able to remove the screw from the panel as it is designed to stay in the panel.
    • Loosen the screw located on the cover of the RAM using Phillips #1 screwdriver.
    • You will not be able to remove the screw from the panel as it is designed to stay in the panel.
  3. With your fingers, carefully remove the middle panel by lifting the edge with the indent. With your fingers, carefully remove the middle panel by lifting the edge with the indent.
    • With your fingers, carefully remove the middle panel by lifting the edge with the indent.
  4. Using your fingers, release the tabs on both ends of the RAM. Pull the RAM out. The other RAM is released in the same manner.
    • Using your fingers, release the tabs on both ends of the RAM.
    • Pull the RAM out.
    • The other RAM is released in the same manner.
Заключение
Еще один человек закончил это руководство.
pfedigan
Участник с: 12.04.2013
11 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 2-23, Maness Spring 2013 Участник Cal Poly, Team 2-23, Maness Spring 2013
CPSU-MANESS-S13S2G23
4 членов
Автор 5 руководств
Один комментарий
how to remove a bios passcode off of a Toshiba Satellite a105 s4374 laptop
simeon cole - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 1,622
