Toshiba Satellite A205-S4577 Front Cover Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A205-S4577 Front Cover Replacement, Battery: шаг 1, изображение 1 из 1
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 2, изображение 1 из 1
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Front Cover Replacement, Speaker Cover: шаг 3, изображение 1 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement, Speaker Cover: шаг 3, изображение 2 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement, Speaker Cover: шаг 3, изображение 3 из 3
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 4, изображение 1 из 1
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 5, изображение 1 из 1
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 Front Cover Replacement, Keyboard: шаг 6, изображение 1 из 1
    • Remove the two 4mm flat-head screws indicated in the photo.
  7. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 7, изображение 1 из 1
    • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
    • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
  8. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 8, изображение 1 из 1
    • The Ribbon Cable must be disconnected here to release the keyboard.
    • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
    • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
    • You can now lift and remove the keyboard.
  9. Toshiba Satellite A205-S4577 Front Cover Replacement, Monitor: шаг 9, изображение 1 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement, Monitor: шаг 9, изображение 2 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement, Monitor: шаг 9, изображение 3 из 3
    • Locate the gray wire on the right.
    • Detach the white end by gently pulling each socket away from the other.
  10. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 10, изображение 1 из 2 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 10, изображение 2 из 2
    • On the left, locate the black and white wires with gold tips on the end.
    • Pull up on the wires to detach them.
  11. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 11, изображение 1 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 11, изображение 2 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 11, изображение 3 из 3
    • Locate the thick tan cord on the left.
    • Slide the tan cord as shown to detach it.
  12. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 12, изображение 1 из 2 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 12, изображение 2 из 2
    • On the right, locate the thick black wire with the white rectangular end.
    • Pull up on it to detach it.
  13. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 13, изображение 1 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 13, изображение 2 из 3 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 13, изображение 3 из 3
    • Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
  14. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 14, изображение 1 из 1
    • Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
  15. Toshiba Satellite A205-S4577 Front Cover Replacement, Front Cover: шаг 15, изображение 1 из 1
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  16. Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 16, изображение 1 из 2 Toshiba Satellite A205-S4577 Front Cover Replacement: шаг 16, изображение 2 из 2
    • Lift up on the front cover to remove it.
Заключение
Еще один человек закончил это руководство.
Cameron Howard
Участник с: 04/16/13
62 Репутация
Автор 3 руководств
Команду
Cal Poly, Team 17-6, Regan Spring 2013 Участник Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 членов
Автор 33 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 1,439
