Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The purpose of this guide is to provide step-by-step instructions for replacing your hard drive. For this process you will need a Phillips #00 screwdriver.
Выберете то, что вам нужно
Locate the hard drive cover on the bottom, left-hand corner of your laptop.
Using a Phillips #00 screwdriver, remove both 4mm screws.
Lift the cover to reveal the old hard drive.
Carefully detach the hard drive from the SATA/Power connector.
