Введение
Before going in and attempting this guide you should have all required materials and tools to properly remove the fan. This may be challenging to be complete. Make sure you follow each step as it is listed.
Инструменты
Запчасти
Никакие детали не требуются.
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Slide the battery release tab away from the center of the laptop and hold it.
Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Use a PH0 screwdriver to remove the screw holding the optical drive in place.
Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
The optical drive will then slide out.
Orient the laptop so that the screen is open and facing you.
Slide the plastic opening tool underneath the top edge of the black plastic insert.
Pull it off and set aside.
Close the laptop and flip it over.
Unscrew the 11 yellow circled screws with a PH1 screwdriver. These screws are larger in size.
Unscrew the 2 red and yellow circled screws with a PH1 screwdriver. These screws are shorter and thicker than the previous.
Unscrew the 1 green and yellow circled screw with a PH1 screwdriver. This screw is longer and thinner than the previous.
Flip the laptop over and open it so that the screen is facing you.
Locate the hinges on either side of the screen, which secure the display to the body of the laptop.
Unscrew the 2 screws in each hinge with a PH1 screwdriver.
Unfasten the connectors from the highlighted locations.
Disconnect by gently pulling on the fasteners which connect the wires to the laptop.
Unscrew the screw indicated by the yellow circle.
Slide the plastic opening tool underneath the edges of the upper casing, which is shown in the images.
The LCD screen can now be removed from the laptop.
Lift the upper plastic casing and remove it from the lower half of the laptop.
Unfasten the two connections shown.
Unscrew the two screws securing the fan to the laptop. Use a PH1 for the screw that is adjacent to the speaker and a PH0 for the other screw.
Lift up the fan and pull the black plastic tab away from the fan housing. Remove the fan.
