Введение
In this guide you will learn how to remove a keyboard safely. Before you begin this guide you should have all required materials and tools necessary to properly remove the keyboard.
Выберете то, что вам нужно
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Slide the battery release tab away from the center of the laptop and hold it.
Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Orient the laptop so that the screen is open and facing you.
Slide the plastic opening tool underneath the top edge of the black plastic insert.
Pull it off and set aside.
3 человек успешно провели ремонт по этому руководству.
