Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Slide the battery lock tab away from the center of the laptop to unlock the battery.
Slide the battery release tab away from the center of the laptop and hold it.
Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
Push outwards on the metal tabs to release the RAM.
Remove the RAM. Some force may be needed.
Use a PH0 screwdriver to remove the screw holding the optical drive in place.
Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
The optical drive will then slide out.
Еще один человек закончил это руководство.
Один комментарий
Question : if i this will my screen start working ng again
