Введение
In this guide you will learn how to remove the RAM. In the case of a broken or unresponsive RAM a replacement may be required. Before begining this guide you should have all required tools that are listed.
Выберете то, что вам нужно
Remove the screw holding the RAM cover with a PH1 screwdriver.
Remove the RAM cover.
Push outwards on the metal tabs to release the RAM.
Remove the RAM. Some force may be needed.
In order to reassemble your device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
