Введение
Ordered a new battery? Have no idea where to start? Well don't worry, this guide will show you how. (Part number should be PA3534U-1BRS) Don't forget to dispose the old battery in an e-waste container.
Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
Find the battery compartment.
Slide the left slider which is just beneath the battery compartment into its leftmost position.
Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
Do not touch the gold nodes inside the compartment.
2 участников успешно повторили данное руководство.
