Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
When your computer heats up and runs loudly, it may need some new fans to keep the runnin' machine cool.This guide will teach you how to get to the fans inside your laptop and replace them. Just make sure to keep track of your screws!
Запчасти
Детали не указаны.
  1. Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you. Find the battery compartment. Slide the left slider which is just beneath the battery compartment into its leftmost position.
    • Close the laptop and turn it over so that the base is facing upwards and the spine is facing away from you.
    • Find the battery compartment.
    • Slide the left slider which is just beneath the battery compartment into its leftmost position.
  2. Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment. Do not touch the gold nodes inside the compartment. Do not touch the gold nodes inside the compartment.
    • Slide and hold the right slider into its rightmost position. Lift the battery out of the compartment.
    • Do not touch the gold nodes inside the compartment.
  3. Place laptop right side up on a flat and clean surface. Open the laptop. Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys. Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
    • Place laptop right side up on a flat and clean surface. Open the laptop.
    • Find the strip just above the keyboard and locate the gaps behind the F1, F8, and Insert keys.
    • Remove the strip by sticking your plastic opening tool into these gaps in order, and pulling up.
  4. Locate the two 2.3mm Phillips #1 screws at the top of the keyboard that attaches the keyboard to the frame behind it. Remove screws.
    • Locate the two 2.3mm Phillips #1 screws at the top of the keyboard that attaches the keyboard to the frame behind it.
    • Remove screws.
  5. Find the latch above the F8 key that overlaps the keyboard. Use a plastic opening tool to press the key board's tab downward, until the key board is released. Use a plastic opening tool to press the key board's tab downward, until the key board is released.
    • Find the latch above the F8 key that overlaps the keyboard.
    • Use a plastic opening tool to press the key board's tab downward, until the key board is released.
  6. Pull the keyboard out by shifting it forward towards the screen and pulling up. CAUTION: Do not pull it out all the way yet. It is still attached to the laptop by a cable.
    • Pull the keyboard out by shifting it forward towards the screen and pulling up.
    • CAUTION: Do not pull it out all the way yet. It is still attached to the laptop by a cable.
  7. Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable. Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily. Pull out the cable and completely remove the keyboard.
    • Find the ribbon cable that connects the keyboard to the laptop. Look for the black tabs on both sides of cable at the laptop end of the cable.
    • Using a pair of tweezers, pull the black tabs on both sides of the cable connector towards the screen until the cable can be pulled out easily.
    • Pull out the cable and completely remove the keyboard.
  8. Turn computer over so that the battery compartment is facing up and is at the top. Locate and unscrew one captive Phillips #1 screw located at the center. A captive screw cannot be completely removed from the device's component.
    • Turn computer over so that the battery compartment is facing up and is at the top.
    • Locate and unscrew one captive Phillips #1 screw located at the center.
    • A captive screw cannot be completely removed from the device's component.
  9. Use a plastic opening tool to open the motherboard access cover. Do not touch the motherboard. Do not touch the motherboard.
    • Use a plastic opening tool to open the motherboard access cover.
    • Do not touch the motherboard.
  10. Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening. Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening. Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
    • Remove one 1.5mm Phillips #1 screw located near the top left edge of the opening.
  11. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  12. Flip your device right side up, and rotate it so that the optical drive is facing you. Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Flip your device right side up, and rotate it so that the optical drive is facing you.
    • Insert a paper clip into a manual release switch located to the right of the automatic release button.
    • Optical Drive will not release if you insert the clip diagonally. Make sure to insert the clip straight into the switch.
  13. Gently pull out the disk drive until you can see the metallic case of the optical drive. Hold the metal case and continue to pull the drive out toward you.
    • Gently pull out the disk drive until you can see the metallic case of the optical drive.
    • Hold the metal case and continue to pull the drive out toward you.
  14. Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click. Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click. Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
    • Once you see the yellow labels on the disk drive, fully retract the disk mount until you hear a click.
  15. Continue to pull the disk drive toward you until it is completely removed from the laptop's housing. Continue to pull the disk drive toward you until it is completely removed from the laptop's housing. Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
    • Continue to pull the disk drive toward you until it is completely removed from the laptop's housing.
  16. Close the lid and flip the laptop over so that the bottom side is facing you. Remove nineteen 8mm Phillips #1 screws, labeled with "F8." Locate and Remove two "f4" screws as well.
    • Close the lid and flip the laptop over so that the bottom side is facing you.
    • Remove nineteen 8mm Phillips #1 screws, labeled with "F8."
    • Locate and Remove two "f4" screws as well.
  17. Locate the RAM compartment. Unscrew the two Phillips #1 screws and lift the lid up. Note that these two screws do not detach from lid.
    • Locate the RAM compartment.
    • Unscrew the two Phillips #1 screws and lift the lid up.
    • Note that these two screws do not detach from lid.
  18. Unscrew the two 8mm Phillips #1 screws inside the RAM compartment.
    • Unscrew the two 8mm Phillips #1 screws inside the RAM compartment.
  19. Remove the three 3mm Phillips #1 screws inside the battery compartment. Remove the three 3mm Phillips #1 screws inside the battery compartment.
    • Remove the three 3mm Phillips #1 screws inside the battery compartment.
  20. Turn computer over and open lid. Make sure all the screws are cleared off the device before you flip the device over.
    • Turn computer over and open lid.
    • Make sure all the screws are cleared off the device before you flip the device over.
    • Remove the four 8mm Phillips #1 screws in the slot where the keyboard sat.
  21. Locate the speaker cables near the top right corner. Use tweezers to carefully disconnect the cable. Use tweezers to carefully disconnect the cable.
    • Locate the speaker cables near the top right corner.
    • Use tweezers to carefully disconnect the cable.
  22. Locate the cable on the bottom left hand corner of keyboard slot. Gently pull it out to the left.
    • Locate the cable on the bottom left hand corner of keyboard slot.
    • Gently pull it out to the left.
  23. Locate the cable at the top of the frame. Using tweezers, pull tabs on either side, toward the screen, and pull the cable out of socket.
    • Locate the cable at the top of the frame.
    • Using tweezers, pull tabs on either side, toward the screen, and pull the cable out of socket.
  24. Locate another ribbon cable at the lower center of the keyboard slot. Using tweezers, pull tabs out to the left, and pull cable out of socket. Using tweezers, pull tabs out to the left, and pull cable out of socket.
    • Locate another ribbon cable at the lower center of the keyboard slot.
    • Using tweezers, pull tabs out to the left, and pull cable out of socket.
  25. Using a plastic opening tool, insert into slit around laptop and separate the silver frame from black bottom. The black lip on the front of the laptop is part of the top silver frame. Lift frame away from laptop.
    • Using a plastic opening tool, insert into slit around laptop and separate the silver frame from black bottom.
    • The black lip on the front of the laptop is part of the top silver frame.
    • Lift frame away from laptop.
  26. Locate the fan in the top left hand corner of the inside of the laptop.
    • Locate the fan in the top left hand corner of the inside of the laptop.
    • Remove the following screws from the fan encasement:
    • Two 12 mm Phillips #1 screws
    • Two 2.3 mm Phillips #1 screws.
  27. Pull away gray flat cable from the fan so that it is no longer stuck to the fan's surface. Disconnect cable by pulling the black end to the left so that it detaches from the white plastic piece. Disconnect cable by pulling the black end to the left so that it detaches from the white plastic piece.
    • Pull away gray flat cable from the fan so that it is no longer stuck to the fan's surface.
    • Disconnect cable by pulling the black end to the left so that it detaches from the white plastic piece.
  28. Using tweezers, disconnect power cable by gently pulling white end straight away from its socket. Using tweezers, disconnect power cable by gently pulling white end straight away from its socket.
    • Using tweezers, disconnect power cable by gently pulling white end straight away from its socket.
  29. Lift fan up out of laptop. Pull out any dust or use a pressurized air duster to clean the fan.
    • Lift fan up out of laptop.
    • Pull out any dust or use a pressurized air duster to clean the fan.
Заключение
7 участников успешно повторили данное руководство.
Grace Cowell
Участник с: 15.04.2013
273 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-12, Maness Spring 2013 Участник Cal Poly, Team 4-12, Maness Spring 2013
CPSU-MANESS-S13S4G12
4 членов
Автор 6 руководств
Один комментарий
I have a Toshiba Satellite P50-BOOG Serial No. YEO15554S. It has sided on me after 18 months and the repair man says it needs a new mother
board. It seems that Toshiba do not recognise the numbers above. I am wondering if this is a copy of Toshiba although I bought it from reputable retailer. Its a lot of money to throw away. Do you know of anyone who deals with Toshiba mother boards in NZ?
clarereid - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 12,847
