Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Installing the RAM is a quick and easy process, just make sure you have the appropriate RAM for your laptop. The Toshiba Satellite A215 S4697 has a max of 4GB of RAM. This means two 2GB of RAM cards.
Выберете то, что вам нужно
Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
Unscrew the two captive screws with the Phillips #1 and open the compartment.
Pull the two tabs away from the RAM so that the RAM will pop out.
Gently pull the RAM away from base.
Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot.
6 участников успешно повторили данное руководство.
Один комментарий
ned solution for my satitillate pro as the fix i need is not listed . my Toshiba is a l875d-s7332 and cu
ls not find the right as the fix given is for and older moldel, can i pls get the right data mailed to my email asasp pls
