Выберете то, что вам нужно
First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
Remove the four screws underneath each cover and place them somewhere secure.
Remove the plastic paneling around the screen, and at the bottom of the display.
Remove the three screws on each side of the display, and place them somewhere secure.
On the back of the display, there is a wire that is plugged in to the display and secured with tape.
Gently lift the tape, leaving it attached to the wire.
Pull the wire out of its socket in the display backing.
The display is now fully detached!
Еще один человек закончил это руководство.
