Toshiba Satellite A215-S7425 Hard Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 2 Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: шаг 4, изображение 2 из 2
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 5, изображение 1 из 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 5, изображение 2 из 3 Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 5, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Static Wrist Strap
    $7.95
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: шаг 7, изображение 1 из 1
    • Slide case away from hard drive.
Заключение
Еще один человек закончил это руководство.
Marianne
Участник с: 09/08/14
647 Репутация
Автор 6 руководств
Команда
Pasco Hernando, Team 5-2, Prince Fall 2014 Участник Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
10 членов
Автор 18 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 12
За последние 30 дней: 22
За всё время: 1,222
