Введение
This guide will give detailed instructions on removing the Toshiba Satellite A215-S7425 keyboard for replacement.
Выберете то, что вам нужно
Turn off the computer.
Disconnect the charging cable from computer.
Flip the computer upside down.
Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
Turn the device so the top side is facing up. Open device to expose key board.
Locate plastic bezel above keyboard and use flat side of spudger to pry away from device.
Gently lift keyboard a few inches above device, exposing the attached ribbon cable.
Gently disconnect the ribbon cable from the motherboard, it should easily slide out from the connector.
2 человек успешно провели ремонт по этому руководству.
