Введение
This guide teaches you how to replace the battery in a Toshiba Satellite A305-S6848 laptop.
Выберете то, что вам нужно
Move the left locking hatch to the left.
Hold the right spring latch to the right.
The keyboard is held in by a locking strip between the screen and the keyboard.
Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
Use your hand to take out locking strip from the right portion that was pried out.
Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
Disconnect the keyboard by flipping the locking clip upwards.
